wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2012, 04:25 PM
Last journal entry: door trim
wiring
Still trying to finish the dash wiring before the snow flies. got home about 6 last night after work and by 7 it was dark. that's what I get for living in Maine. Managed to wire the column and also managed to short something out at the same time. Key was off but battery was connected, now none of my gauges work. Car still starts and lights work, checked all the fuses none blown. Have no clue what I did.
Old 09-12-2012, 07:08 PM
LATECH's Avatar
What type of gauges do you have? is there a printed circuit?
Fact is stranger than Fiction
Old 09-14-2012, 01:37 PM
autometer gauges, and there is no printed circuit, sc
Old 09-14-2012, 02:31 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
hurry up and f up
If you shorted something and no fuses are blown you better find out what shorted and make the repair.
How are you checking the fuses? Visual is no good use a meter or a test light.
Possibly the fusible link or main fuse is blown.
Possibly a bad connection somewhere.
Check for 12 volts to the gauges.
vicrod
Old 09-15-2012, 09:17 AM
thanks i just did a visual check I will use my meter when i get out of work today. sc
Wiring johns79camaro Electrical 4 10-29-2010 08:05 AM
EZ wiring - back up light wiring copdwg Electrical 3 06-07-2008 06:42 PM
is this wiring ok? Jzarczyn Electrical 2 09-28-2004 02:29 PM
wiring have a go murraydavidson Electrical 4 05-29-2003 09:20 AM
rs wiring 67rscamaro Electrical 2 02-18-2003 05:59 PM
