From the info, this is really a WAG. I think you have two separate problems. A horn ground at the steering wheel that should be "open" until pressed, and (a real guess here) a jumper from the solenoid terminal to the starter main lead, and you've either neglected to put in the necessary "Ford" style solenoid, or you've installed it either wrongly, or the solenoid is defective. Is there a chance in he11 that I'm right on either account? As noted, purely guesses.
Pat |
Wiring
PATM, you are amazing. I taped the ground wire on the steering wheel and amazingly when I connected the battery no horn and no starter. Could it be that little stick-en ground wire was causing all that mayhem? I felt like I was welding with my battery cable. I did notice that the headlights and the hazard lights were working. Also i keyed up the car and all of the gauges fired up. I guess that is a real good sign. However I found that my turn signals are not working. Still have not checked the fuse, it is possible I fried something trying to hook it up. My concern is that once I install the horn will my starter kick on everytime I honk?
wiring diagram ?
Did your harness come with a good wiring diagram ? I bought a 20 circuit harness at a swap meet new in box but no diagram for $ 50. I went to the EZ2wire website and printed off their instructions, diagrams. and I always double check the wiring before testing my work. Smoke is expensive.
wiring
The instructions that came with this ezwire harness are a joke. They basically have no tech support to speak of. Next time around i will just use a Painless. I bought a Painless temp sensor harness and the instructions were amazing.
| Tags |
| wiring |
| wiring HELP?? | the82elco | Electrical | 12 | 11-01-2012 05:32 PM |
| Need Some Wiring Help Please | chevyrestore | Electrical | 35 | 05-10-2011 11:46 PM |
| EZ wiring - back up light wiring | copdwg | Electrical | 3 | 06-07-2008 06:42 PM |
| Wiring | mendenc | Electrical | 1 | 07-11-2003 09:42 PM |
| wiring | norm671 | Engine | 0 | 06-25-2003 02:41 AM |
