Wiring a 60s Chevy steering column
I am putting a 1960 Chevrolet steering column into a 1937 truck. And besides from shorting it. It fits. But I have a wiring question. I know I don't need to use all of its 7 wires. Its a floor shift truck. So all I need to use is the horn wires and turn signal wires. It has a neutral safety switch but I am not using it. Here is the list of wires: first plug has a : Purple wire
3 wires Black with white stripe Black with yellow stripe Second plug has a : Green wire 4 wires Black with blue stripe Blue Black Have any idea which wires I need to use for just the horn and turn signal. and what they go to. It was a 3 speed on the column. No key THANKS ! |
Sorry It was a purple wire, black wire with white stripe and a black wire with
a yellow stripe. The second plug has a green wire,black with blue stripe wire, blue wire and a black wire. it came out wrong the first time. |
May find Info on this diagram, you can download it so it's larger>> http://www.mygreatstuff.com/wiring
Was originally here>> http://67-72chevytrucks.com/vboard/s...d.php?t=185856 |
Hard to read but my diagram = LG-back up light , B-horn, LBL-turn, DBL-turn, Y-rear turn, DG-rear turn, BRN-fuse box, PPL-neutral safety
Info here also, Pg. 10 or Pg. 16 by Acrobat Pdf.
http://www.painlessperformance.com/Manuals/10102.pdf |
| All times are GMT -6. The time now is 07:06 AM. |
