wiring-in alternator and accessories - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2008, 02:06 PM
Hi again. I have several questions. This is a GM type application using a 10SI alternator.
1 -- DocVette advocated wiring the small red alternator wire to the horn relay "hot" connection. I think most wiring kits simply jumper over to the Alternator's "batt" terminal. Is there a reason to set this up with a longer lead, should I perhaps consider even running this lead from switched power?
2 -- I plan to use a voltage regulator, and a choke relay. I believe the choke relay should be triggered by the voltage sensing wire, and that the voltage regulator should be wired with one pole to the VS lead, and the other to a good ground. Is this correct?
3 -- Is it possible to use both a voltmeter and an idiot light (one is built into my voltmeter, but I'm not sure how or where to hook it up)?
4 -- Do I need to use an in-line resistor or diode with this setup?
Lastly, if you have (or can easily create) a diagram with alternator, voltmeter, idiot light, resistor or diode if necessary, and electric choke all shown, I'd love to see it.
Thanks in advance.
Pat
Old 06-18-2008, 02:13 PM
Holder350's Avatar
Auto Parts Professional
Heres a diagram that should help a bit....the GM alt your going to be using has a voltage regulator built into it....no need for a diode or resistor.
Old 06-18-2008, 02:19 PM
Thanks. Confirms where the warning light goes, in the event I had a ammeter. But this should function similarly with a voltmeter, I think.
Pat
Old 06-18-2008, 02:24 PM
Holder350's Avatar
nope...if its a volt meter then it just wires, positive and ground to any switched source.
Old 06-18-2008, 03:37 PM
So, rather than Voltage Sensing to ground, I should use a switched power source to ground. Off the accesory side, I take it.
Pat
Old 06-18-2008, 04:54 PM
Holder350's Avatar
right a voltage meter just senses the voltage that the alt is putting out....lots of newer radios with LCD displays have a voltage gauges built in.....pretty sweet too
Old 06-18-2008, 08:42 PM
The stock GM wiring diagram is a little simpler than the picture (solenoid is on the starter and coil is in the HEI cap), but most of the connections are basically the same.
The full current ammeter connection is much different than I've seen in early '70s GM vehicles. I think Chrysler used a full current ammeter, but GM used some type of comparator circuit to measure amperage. The GM wiring setup was a lot safer because the high amp draw did not go through the wiring to the dash.
If you have GM HEI ignition, you also won't need the ballast resistor shown in the diagram.
Bruce
Old 06-18-2008, 11:41 PM
malc's Avatar
Living At The Speed Of Life
Have a read through The Chevy Main Electrical Power Up System at Madelectrical.
There are also articles on the 10SI alternator and why amp gauges are not desireable in a vehicle.
Brake light switch wiring... 38 special Electrical 10 09-15-2007 06:54 AM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 02:28 AM
1956 chevy belair Wiring Diagram NAK Electrical 1 05-12-2005 09:22 PM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
