wiring for Caddy 400 trans
ok i've done a search & couldn't come up w/the answer i needed soooooooooooo i'll ask here.
i need a wiring diagram for the electronic transmission kick down for my 78 Caddy 425/400 combo...thanks...joe |
There's not much to wire. The kickdown solenoid simply needs a switch somewhere on the throttle linkage that closes at wide open throttle and sends +12V to the trans. Does your trans have one terminal or two on the connector? Some 70s-vintage TH400s have a second signal coming from the trans that operates emissions control hardware in certain gears. That's unrelated to the kickdown. This is also not to be confused with the 60s-vintage TH400s that have the dual stall speed torque converter.
On my Turbo 400 ... I just fabricated up a simple bracket that holds a switch ... when it is pulled ( adjustable ) ... it sends the 12V to the Turbo 400 and activates the passing gear. |
thanks folks i knew it was something simple BUT wanted to be sure how it was hooked up, that & the fact i hate to do electric and just wanted to be sure how it hooked up.....joe
| 454bbc with t 400 trans 19471/2ton chevy pick up | timbro 42 | Engine | 8 | 03-11-2009 07:03 PM |
| Turbo 400 trans speedometer gear? | Pro Street | Transmission - Rearend | 5 | 06-19-2006 05:42 AM |
| 4L80E diesel computer | 5foot2 | Transmission - Rearend | 2 | 04-09-2005 12:48 PM |
| 350 trans bolt to a 400 engine. | greg67 | Engine | 2 | 11-05-2003 11:27 PM |
| wiring diagram for 1986 trans am | 1986 Trans am | Electrical | 3 | 10-20-2003 05:00 AM |
