Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring compressor
  #16 (permalink)
Old 11-23-2008, 08:53 PM
bluesman2333 bluesman2333 is offline
1947 Chevy Coupe
Just L1, L2 and the ground are sufficient. These will be the wires from a two pole breaker and the ground bus in the panel. If you are running romex, you will have a black white and bare wire. Relabel the white wire with red tape, it will be a hot not a ground in your circuit. If you run EMT or other raceway, pull a black, red and green in the pipe.
