Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring compressor
  #19 (permalink)
Old 12-09-2008, 01:58 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Originally Posted by bluesman2333
Just L1, L2 and the ground are sufficient. These will be the wires from a two pole breaker and the ground bus in the panel. If you are running romex, you will have a black white and bare wire. Relabel the white wire with red tape, it will be a hot not a ground in your circuit. If you run EMT or other raceway, pull a black, red and green in the pipe.
I might add, according to NEC re-label both ends of that white wire now that it will be a hot.
Vince
