Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring compressor
  #23 (permalink)
Old 12-11-2008, 09:24 AM
scotzz scotzz is offline
Originally Posted by roger1
A dryer circuit should be on 10 gauge wire.
Old code would be 10-2 w/ground and new code is 10-3 w/ground. are right.......the dryer circuit is 10 ga wire with a 30 amp double pole breaker. Using 10-2 w/ground wire ............does the neutral pin on the plug get wired to the ground?
