Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring compressor
  #27 (permalink)
Old 12-21-2008, 07:50 AM
scotzz scotzz is offline
Originally Posted by bluesman2333
In a residential install, the neutral will be ground. You need to tape it green and re-land it to the ground bus if there is one. With this outlet, you need to run a minimum of #8, so the dryer circuit wiring will be too light if that's what you used.
Why do I have to use #8?
