Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring compressor
  #29 (permalink)
Old 12-21-2008, 09:14 AM
bluesman2333 bluesman2333 is offline
1947 Chevy Coupe
The maximum wire size is governed by one of three things. 1) If the load is a motor load like a compressor which has a high current start out of proportion to the running current, 2) the distance between the circuit breaker and the load causes voltage drop, or 3) if you have a certain plug configuration as is your case. A 10 gauge wire will not support a 50 amp circuit.
You need to install the correct sized wire and circuit breaker.
