Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring compressor
  #61 (permalink)
Old 12-28-2008, 08:07 PM
roger1's Avatar
roger1 roger1 is offline
Originally Posted by bluesman2333
It is telling you to wire the feeder with a 40 amp circuit at a minimum. A super lag is one type of fuse that is able to withstand higher than normal inrush currents. Circuit breakers normally withstand momentary high inrush currents.
If I were you, I would give up on the shared circuit idea and wire in a separate circuit.
Yep. Don't fool around.
