Elect code
The national elect code is a guide and states counties or cities can adopt the codes..ELECT, BUILDING, PLUMBING. ETC and the goverenment agencies can make additional rules.
Not good to do. |
I reread the extra context that you felt was missing..now in your and Bullheimers area that may be the case...however the comment wasn't about new houses in his or your area it was EVERY new house. I just happen to know that locally that is NOT true. It is unacceptable locally, that would eliminate EVERY new house. It is not allowed in any service, I don't care whether it is entrance or range service it is NOT allowed. I also made sure that I stated that I wasn't sure whether it was a National or local. So it apparently isn't National, but I am more than aware of local ordinances, several of my good friends are master electricians as well as my son-in-law. That's the main reason I suggest checking your local building codes. Since this is really an International forum some things aren't universally applied. I know that Rods/Custom builds are pretty easy to register here in Illinois, I do it regularly, but I wouldn't even want to try it in Ca., or some other states....Ca. is the most notorious that's why I mentioned it specificly. I have no personal opinion on the Al. wiring,I do know that inspectors can be tough. So it's always better to be informed of local standards. NOW, as a caveat, some stuff done by the homeowner on their own, doesn't require certain things...like a licensed electrician...but, I think stuff like wiring standards still have to be met.
Getting back to fire insurance, when a fire occurs and the homeowner wired a circuit that causes a fire, the homeowners insurance may not cover the fire. I would say will not, but I'm sure somewhere there is an exception. The other side of the coin is why skimp to save a few bucks when the stakes are so high? Would you skimp on the size of your brake lines or take a chance on running bald tires on the highway with your family in the car? Why do it with a circuit in your garage? |
He will either plug a 30 Amp dryer into this receptacle or unplug the dryer and plug in a welder (with an extension cord) which is supposed to be on a 20 Amp 220V circuit. So, the problem isn't what you state. And, the problem isn't running the dryer, it is running the welder on a 30 Amp breaker when it is designed for a 20 Amp circuit. If his extension cord is #10 then he's probably running Romex as an extension cord which is not designed for that. If he is using a standard extension cord, the largest available for those is #12 and it wouldn't be good to run #12 wire on a 30 Amp breaker. |
The feed cord on your 20 Amp welder will be #12 wire. It will not be protected with a 30 Amp breaker and will create a hazard even if your extension cord is #10. |
How do I unsubscribe this thread , as I believe all the electricians out there have beat this to death and haven,t heard from ANGLIABOB , so his thread has been stolen !
These include voltage drop and overheating of plugs and cord caps due to overload from high starting currents and loose fitting connections. Plugs are by nature loose fitting, otherwise you couldn't insert or remove them. Hooking an air compressor to a 240 volt circuit with an extension cord is not a good idea. |
Found the unsubscribe , thanx.
If I were you, I would give up on the shared circuit idea and wire in a separate circuit. |
| Recent Garage - Tools posts with photos |
| Used compressor - rusty tank? | Slipangle | Garage - Tools | 15 | 03-16-2012 08:51 AM |
| wiring in air compressor | mitmaks | Garage - Tools | 60 | 04-14-2007 05:02 PM |
| air lines | CARGUY | Garage - Tools | 96 | 11-16-2006 04:11 PM |
| Wiring an Hour Meter to my Compressor. | 58Chev | Garage - Tools | 6 | 12-18-2005 10:24 AM |
| Wiring my 230v compressor...... | PairOf69's | Garage - Tools | 7 | 11-18-2005 08:04 PM |
