wiring diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2010, 06:30 PM
wiring diagram
i recently bought a 74 gmc pickup my problem is when i pull out the headlight switch to the first click( for just marker lights on ) they do not come on, or do the tailights , but when its pulled all the way out the headlights /tail lights do come on,im looking for a very clear wiring diagram to try to figure this out, it apparently has a new headlight switch already any ideas would be much appreciated,,,,,,,,,,
Old 09-01-2010, 07:04 PM
I think you have a bad switch. This is how I would check the switch. To do this I would unplug the connector from the switch. I would use a test light to find the wire(s) that are hot. I would then make up a jumper from the hot supply moving it around touching it to all other wires testing to see if the lights light up like they are supposed to. If they do then you have a bad switch.
Old 09-01-2010, 07:23 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The links will take you to a 72 gmc wiring diagram, hope it helps.
Good luck,
Rich
http://www.flickr.com/photos/boundst...10207/sizes/l/
http://www.flickr.com/photos/boundst...11656/sizes/l/
Old 09-01-2010, 11:53 PM
This is a 73-76 diagram from Chiltons
Old 09-01-2010, 11:58 PM
Try again. Forgotten how to do attachments. If it doesn't work this time I'm going to bed.
Old 09-02-2010, 12:06 AM
OK, this is definitely that last try
Old 09-02-2010, 09:44 AM
The wires to the park and tail lights are the same, only the contacts in the switch are different. This pretty much narrows the problem down to the switch.
Old 09-02-2010, 10:44 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Switch x 2
Old 09-02-2010, 06:11 PM
wiring
hey brian , and everyone else, much appreciated im going to try a new switch and see what happens,,,,,,,,,,thanks again guys,,,,,,,,,,
need wiring diagram 1954 ford car btull Electrical 1 04-28-2007 08:35 PM
1996 Big Block Chevy Wiring Diagram Sick56 Electrical 2 01-02-2006 02:31 PM
Need wiring diagram for Alt. 1966 Mustang Aussie XAXB Electrical 2 11-15-2005 07:41 AM
1956 chevy belair Wiring Diagram NAK Electrical 1 05-12-2005 09:22 PM
Need Wiring Diagram for 71 Nova sonicse Electrical 5 01-24-2003 12:24 PM
