Wiring diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2011, 05:51 PM
Wiring diagram
Hi guys new to the site but I have been following for a while. I just bought a 65 chevy stepside for my girl but the gas guage and speedo do not work. I currently have her checking the gas with a stick lol. I have been searching but cant find a wiring diagram for the gas gauge. Can anyone out there help me please.
Old 03-25-2011, 06:19 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Welcome to Hotrodders.com Glad to have you with us
Have you checked your sending unit to verify that it's good? Take an ohm meter and check the resistance from full to empty. It should be 0 to 30 ohms. If it checks out then you need a new gage. The tank's still behind the seat right?
Rich
Old 03-25-2011, 08:10 PM
behind the seat
yup its still behind the seat so that should be easier right? lol im a newbie. I tried to take of the gauges so I can get the the speedo cable behind there also because i here something move, what do I need to remove? and where does the speedo cable come into the cab? I tried to feel back there but couldnt tell.
Old 03-25-2011, 08:49 PM
You will have to remove the headlight switch. Push the little spring loaded button on the back. Then pull out the shaft. The wiper switch is easier and also the ignition switch. If you have a choke remove it and remove the wire for the lighter. And if you have an oil gage you have to take the feed line off as well.
Now look at how the speedo cable is held in with that clip thing push on it & the cable will pull out.
Rich
Old 03-25-2011, 08:53 PM
choke
Ok i have the headlight switch, ignition and ligheter out, but for the life of me I cant take the choke off. I took the nut off the back of the choke and I can pull the cable up but not back off. How do I take off the knob?
Old 03-25-2011, 09:05 PM
the choke comes through a bracket, there should be nut on both sides
Old 03-25-2011, 09:10 PM
the one i took off has a nut behind the bezel and in front its the knob, then the shaft that goes into the chrome peice with the threaded peice where the nut goes from the back. I tried to take that chrome peice out but It just spins..Doesnt the knob have to come off?
Old 03-26-2011, 05:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IIRC there's a small set screw holding the knob on for the choke. If no set screw, the knob should unscrew.
Old 03-26-2011, 08:50 AM
Thanks guys just woke up so im going back to try
76 350 Wiring Diagram mightycarlo10 Electrical 0 12-29-2007 11:25 AM
tbi wiring diagram lanierledford Electrical 1 01-24-2007 07:19 PM
wiring diagram samswrld1 Hotrodders' Lounge 2 01-19-2006 01:19 PM
wiring diagram 66carpetman Electrical 6 10-26-2005 04:22 PM
wiring diagram 455c-10 Electrical 1 10-19-2005 10:58 PM
