wiring diagram for 69 ford f100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2011, 11:44 AM
cant get fire from ignition to cyilnoid
Old 12-23-2011, 07:08 AM
delawarebill's Avatar
no fire
does it still have points??? start at the ign sw and ck for +12v there, then go to the ballast resistor and ck both sides, the out will be a little less V's, ck both sides of coil for power. now all this has to be done with the poiints open or pull the outlet side of the coil off (wire going to points). if u get power on the IN side of ballast or coil but not the outlet then replace that item.. also this is with the sw in the ON position.
wiring diagram for 1969 ford f100 d&c repairs it all Electrical 2 08-09-2011 01:09 PM
audio wiring diagram for a 1969 ford f100 B.J. Electrical 2 07-04-2011 08:22 AM
Wiring diagram 1969 F100 jimlittleenterprises Electrical 1 04-01-2011 12:26 PM
52 ford f100 wiring diagram? jvsapp Electrical 1 09-06-2007 11:41 AM
75 f100 wiring diagram spooki Electrical 0 01-14-2004 06:22 PM
