wiring diagram for brake light/indicator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2006, 12:42 PM
Last journal entry: Better late than never
I am finishing up the wiring at the back end of the car and have 2 filament bulbs at the rear to take care of the night light, brake light and indicators.
I wired the night light to the duller of the two filaments and BOTH the 12v brake light feed and each indicator to the brighter filaments.
Of course my problem now is that when I indicate either left or right both indicators flash simultaneously at the back, front is fine. They are using the 12v feed for the brake light to feed 12v from one indicator to the other.
Does anyone have a simple diragram on how to wire the back lights for the three functions so they dont affect each other?
Thanks,
Old 06-06-2006, 02:04 PM
302 Z28's Avatar
Brake lamp wiring feeds through the turn signal switch, that is where the turn indicator lamp wiring feeds the stop lamps. Here is a link with some wiring diagrams.
http://www.autoforumz.com/Turn-signa...ict158538.html
Vince
Old 06-06-2006, 02:58 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
What car is this in..? What column..?
Here is a basic early GM Wiring from the column plug..
  • Light blue=Left dash indicator & Front Left Turn Lamp
  • Dark blue=Right Dash Indicator & Front Right Turn Lamp
  • Yellow=Left Rear Stop/Turn Lamp
  • Dark Green=Right Rear Stop/Turn Lamp
  • White=Stop lamp Switch (& Hazard If used)
  • Purple=Turnsignal Flasher
That for 70 ~ ish on down GM's..I think later will be the same or similar also.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
1996 Big Block Chevy Wiring Diagram Sick56 Electrical 2 01-02-2006 02:31 PM
Need wiring diagram for Alt. 1966 Mustang Aussie XAXB Electrical 2 11-15-2005 07:41 AM
1956 chevy belair Wiring Diagram NAK Electrical 1 05-12-2005 09:22 PM
Need Wiring Diagram for 71 Nova sonicse Electrical 5 01-24-2003 12:24 PM
wiring diagram for a ford F-100, 1970 musmly Electrical 2 05-27-2002 09:50 PM
