Wiring diagram for electric fuel pump... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2008, 10:48 AM
Sinister's Avatar
I need a wiring diagram for an electric fuel pump,
with a relay and oil pressure switch.
Old 09-19-2008, 11:32 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I don't have a diagram, but I can describe it.
Find a switched power source. Fused 10 ga wire goes into post 30 on the relay with a jumper to post 86.
Out from post 87 goes a 10 ga (or sufficient) wire to the fuel pump.
Post 85 will go to a normally-open oil pressure switch. That is to say, an oil pressure switch that grounds when it has pressure. There are switches that ground when there is no pressure, then open when there is pressure. If you have that kind of switch you're OK, just get a DPDT relay (it will have five prongs) and hook up the wire to your pump to 87a instead of 87.
Old 09-19-2008, 11:46 AM
Sinister's Avatar
Cool, thanks Curtis.
Old 09-19-2008, 11:48 AM
Jmark's Avatar
What if it's a cheap relay that only has "A, B, C, D, and E"? LOL
Old 09-19-2008, 01:30 PM
curtis73's Avatar
Wiki Edits: 16
Then I use the "plug and pray" method.
Old 09-19-2008, 02:21 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
The information given is incomplete it does not allow the car to start with 0/zero fuel pressure ............................see this link
http://www.mr-gasket.com/pdf/110_140.pdf
page #3 figure 3 shows a digram and parts needed along with wiring
Old 09-19-2008, 02:46 PM
curtis73's Avatar
Wiki Edits: 16
While I agree, it doesn't make much of a difference. I used the wiring I described on my boat. First of all, the fuel in the bowls (if its carbed) will get you started and run for a while - long after the pump has already kicked on. Secondly, after a couple cranks of the engine there is enough oil pressure to kick the switch on, so even in something like a TBI it results in only another half second crank time. Third, on my boat after its been sitting for all winter, I just pull the wire off the oil pressure switch and ground it to the manifold for a couple seconds to fill the bowls.
Old 09-20-2008, 01:23 AM
malc's Avatar
Living At The Speed Of Life
On the relay,
30 goes to battery direct with fuseible link.
86 goes to the oil pressure switch.
87 to fuel pump.
85 to ground.
On pressure switch,
P is from relay 86.
S is to start circuit.
I is to switched ignition.
Old 09-20-2008, 02:18 AM
curtis73's Avatar
Wiki Edits: 16
Originally Posted by malc
On the relay,
87 to fuel pump.
85 to ground.
On pressure switch,
P is from relay 86.
While that might work with some European cars, most oil pressure switches here in the US have one connection. Its a single connector that (depending on oil pressure) is either grounded or not. So I think for the problem at hand your wiring won't work.
I also have a problem with wiring the power supply from the battery. First of all, there is no reason to do it, and secondly, if the oil pressure switch fails in the closed position, the fuel pump will run continuously even with the switch off. That is why I wire the supply line from a switched source. Even if the oil pressure switch fails, you can continue to run the vehicle almost indefinitely until you get a new switch. You just have to be careful about how long you leave the switch on if the car isn't running.
Old 09-20-2008, 03:33 AM
malc's Avatar
That is not for European cars, only U.S. vehicles and I got it from a reputible
person dedicated to wiring American vehicles.
The recommended oil pressure switch is ACDelco G1809 costs $7.56 from
RockAuto.com and has three connections.
(GM 3986857 also)
The pump needs a full 12 volts, thatīs why.
Old 09-20-2008, 03:37 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
For those hard to start cars you could build a primer circuit that runs the pump for 2 seconds when the ignition is turned on. Your ECM should do that anyway. For carbs just hook up a second circuit with a momentary switch so you can prime the carb if you need to. My carb setup will idle for 15 seconds or so without fuel pressure.
Where are you putting the oil pressure switch?
Old 09-20-2008, 09:06 AM
SSedan64's Avatar
Here's a good post about electric pump & choke wiring. You can use the "R" terminal on the starter for power to the fuel pump before oil pressure builds up.
A question for you electric choke guys
Old 09-20-2008, 10:24 AM
LOL,,,don't guess!!!! test!!!!
many ign switches do also apply power to the "on" contact while in "start" position.....(so the pump will run in start)
on a switched source, if the volts at the coil doesn't drop at idle with the added pump amps your basically fine....
(compare coil volts with the pump hot wired to another cars batt to tell if the volts are the same at the coil at idle)
alot depends on the actual when running total amps load at idle versus alt at idle amps output if any....
a majority of the oem harnesses do have "some" reserve amps capability but,,, with age and use you do loose some of that reserve!
so my $.02:
switched or batt direct install depends on the specific application and which pump...
there are definitely good and bad points for either power source...
I would use a accident impact kill switch on a batt direct install!
Old 09-20-2008, 11:10 PM
Somewhere in the vast wasteland of my mind I seem to remember something about using an oil pressure switch from a Vega to wire up a fuel pump.
Old 09-21-2008, 01:17 AM
malc's Avatar
The oil pressure switch part numbers I gave are for a 74 Chevy Vega.
electric fuel pump question sexypizzaman Engine 26 05-19-2015 08:13 AM
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 05:27 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 04:17 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 07:38 PM
fuel pump wiring 68bird Electrical 4 06-17-2004 11:25 AM
