Wiring diagram for fuse panel 69 F150 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2010, 09:16 PM
Someone (an unnamed nonhuman) took a torch to the wires under my dash. I have another fuse box I am wiring into my 69 F150. Naturally, all the wires are not exactly the same. I have some wiring diagrams from fordification but it is not specific enough, i.e. it shows three fuses when there are actually 5 (or 6). Anyhow, there are two black wires, 8 gauge, one goes to the alternator and one to the start ignition. One has a yellow tracer, and hte other has an almost yellow/green tracer. What I need is a fuse panel diagram since the fuse box I picked up is not a 69, it's probably a 70 or71. Does anyone have any advice? thanks, ltca
Old 08-13-2010, 03:44 AM
67Mustang Al.'s Avatar
Wiring worries.
Just working my way through a 67 Mustang with an EZ wiring harness which has all wires marked. Its a mystery when you are working with unmarked wires and a big help is a multimeter to find which wires are carrying +12 volts when the ignition is on/off.
A basic alternator diagram here may be of some use to you. This diagram is for a vehicle that runs a red alternator warning light. Note the small resistor which is wired in"parallel" ( runs parallel to the wires in and out of the light). This will make sure the alternator still charges if you lose the "red" alternator globe for some reason.
This is not exactly what you are looking for but it may help a bit.
Where do I get wiring diagram / "how-to's" for a 67 Lemans? riverdale Electrical 8 07-26-2015 12:50 PM
wiring diagram for 75 chevy C10 PU DOUBLEDICK Electrical 11 05-28-2007 02:45 AM
need wiring diagram 1954 ford car btull Electrical 1 04-28-2007 08:35 PM
Wiring Diagram for 88 & 86 S-10 cas2042 Electrical 1 03-16-2004 09:20 AM
INSTRUMENT PANEL WIRING bluechev4x4 Electrical 0 12-28-2002 01:01 PM
