wiring in different motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2008, 05:29 AM
5.7s10's Avatar
hello everyone, I have searched through posted threads but I'm looking for a more direct answer any help is awesome-
I have an 89 2wd s-10 that I am finally finishing up the engine swap from the 2.5 to a used 400 sbc and i would like to know the best way to connect wires properly from the ignition to the distributor,starter and anything else(how to id the correct wires) . The motor has a carb,hei, no ac. This project has taken a lot longer than i anticipated. Any help is great,Thanks.
ps how do you change you name on here?
Old 05-23-2008, 05:45 AM
red rs ss 68's Avatar
no substitute for cubic inchs
hi should be as simple as putting the original starter wires back on the new one with your hei just run a new 12 volt wire out of your fuse box should work fine alternater should be a one wire to the battery and one to your dash light. to change your name go to the top of the page your on and select user cp when you get to that page you will find edit profile on your left use that. sean
Old 05-23-2008, 08:19 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Jon is the only one that can change your user name..... PM him and tell him the name that you want to change too.
Old 05-23-2008, 01:40 PM
5.7s10's Avatar
thanks
thanks for the info guys
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
looking for wiring for 2 speed wiper motor on 68 chevy pickup trkitchens Electrical 1 03-20-2008 07:12 PM
Turning Newly Built Motor nootkabear Engine 43 03-19-2008 01:56 PM
wiper motor won't run cboy Electrical 14 05-03-2006 09:44 AM
