Wiring for drag car - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-24-2009, 09:08 PM
So just run the braided ground straps sort of like the stock ones. Should I just connect an 8 gauge wire to the fuel pumps hot wire(I'm guessing 16 gauge) right where the wire goes into the pump. But the battery running straight into a 30 amp switch through 8 gauge wire won't fry the switch.
  #17 (permalink)
Old 12-25-2009, 11:56 AM
302 Z28's Avatar
I don't mean to sound disrespectful, but I think it would be a good idea for you to seek some input from someone locally who is familiar with auto electrical work.
I'm a little pressed for time right now with relatives coming over for Christmas dinner, but after things settle down I will try and put together a CAD drawing of a simplified wiring diagram for a main disconnect switch, fuel pump switch, and ignition switch.
Vince
  #18 (permalink)
Old 12-27-2009, 11:01 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Check out oil pressure switch wiring diagram that is noted here: http://www.holley.com/data/TechServi...ech%20Info.pdf
Today for the first time I judged a car show. MARTINSR Hotrodders' Lounge 7 06-07-2008 06:45 AM
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 09:09 AM
need wiring diagram 1954 ford car btull Electrical 1 04-28-2007 09:35 PM
sock car wiring racenred#4 Electrical 1 03-02-2006 03:09 PM
