Wiring for drag car - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2009, 04:13 PM
Wiring for drag car
I am running the wires in my El Camino drag car and have stumbled into a problem. I am running the main power wire from the battery to my main power toggle switch, but the wire is carrying to many amps for the switch and the smaller wires for the gauges and etc... I was wondering what I could put between the battery and main switch to stop this problem. It just melts the smaller wires as soon as i hook up the battery.
Old 12-23-2009, 04:56 PM
302 Z28's Avatar
You need a relay. What is you total load your needing to run from that one wire?
Vince
Old 12-23-2009, 06:48 PM
I will be running a Red Holley fuel pump, gauge lights, and the ignition system if possible.
Old 12-23-2009, 07:14 PM
302 Z28's Avatar
The Holley fuel pump needs to be on a relay as does the ignition system. Both of those also need their own fuses. I would use automotive 30 or 40 amp rated 12 volt relays.
Vince
Old 12-23-2009, 09:28 PM
Thanks I will do that, but my switches are rated at 250 amps and I need to get the amps down directly off my battery so....
Old 12-23-2009, 09:44 PM
If you are melting wires you are doing something wrong, you can't "get the amps down" . Whatever you hook to the battery will pull however many amps is necessary for that item to work.
Tell us just how you have it wired and what gauge wire used and what you are wiring up and just what item is melting the wire.
Old 12-23-2009, 10:34 PM
302 Z28's Avatar
then you have a serious wiring problem. What switches do you have that are rated at 250 amps?
Vince
Old 12-23-2009, 10:46 PM
RSM's Avatar
RSM RSM is offline
Sounds like something is grounded if you burn wires as soon as you connect power...unless i'm reading it wrong.
Old 12-24-2009, 01:21 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am having a hard time understanding this..Why not get one of the 12 circuit harnesses from EZwire or other vendor and wire it up per instructions..that is what most of us do..
Sam
Old 12-24-2009, 09:04 AM
I am running 8 gauge wiring, all the grounds are hooked up that need to be. The main wire for the main switch come directly off the battery.
Whats size relays should I use for the fuel pump and the ignition?
Old 12-24-2009, 09:38 AM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like your switch is only turning of the heavy cable, this leaves the lighter wires to carry the load and they cant handle it, so they get hot and burn
Chet
Old 12-24-2009, 12:14 PM
302 Z28's Avatar
See post #4.
Vince
Old 12-24-2009, 08:24 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Where did you put the battery? In the trunk? Did you run a negative wire back to the engine compartment? OR, are the smaller wires acting as a grounding wire and that is why they're 'heating' up.
Check this link:Guage Wire to Remotely Relocate Battery?
Old 12-24-2009, 08:33 PM
For now the battery is in the engine compartment. I have the main ground to the frame. The grounds for the lights and fuel pump are smaller black wires to the frame. Do I need to run a very large ground wire for the lights and fuel pump?
Old 12-24-2009, 08:41 PM
Wiki Edits: 647
I use braided ground straps to run from the frame to the body, and the body to the engine Plus I run a 8 ga, ground to my fuel pump. Positive wire to pump is 8 ga. also. Eliminates any back feed, IMHO.
Today for the first time I judged a car show. MARTINSR Hotrodders' Lounge 7 06-07-2008 06:45 AM
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 09:09 AM
need wiring diagram 1954 ford car btull Electrical 1 04-28-2007 09:35 PM
sock car wiring racenred#4 Electrical 1 03-02-2006 03:09 PM
