Wiring Earley Jaeger Temp Gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2010, 12:19 PM
rollenhard's Avatar
Need help wiring jaeger temp gauge.On the backside of the gauge there are two letters stamped left side the letter T on the right side the letter B. Witch wire goes where.
Thanks
ID:	47301   Click image for larger version
Old 08-10-2010, 07:46 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Thanks
I do not know absolutley positively. However if I was going to guess I would say the B terminal is for instrument voltage ( from the instrument regulator) and the T is for the Temp sender. The other mounting posts most likely ground it .The double spade on the B terminal is probably to daisy chain the next gauge to instrument voltage . Like I said its only a guess.
Try looking at http://advancedautowire.com it looked like you might find what you need here
Old 08-10-2010, 07:47 PM
LATECH's Avatar
The triumph tr 3 diagram looked helpful
Old 08-11-2010, 07:45 AM
rollenhard's Avatar
Thanks for the reply latech
I will check out that website later today.I probably should have said im running this gauge in my 53 Chevy truck 350 V8.
Thanks again
Old 08-11-2010, 01:12 PM
rollenhard's Avatar
Well i ended up connecting the hot to b and the sender wire to t and it worked great. Now i have a temp gauge thanks for the help guys.
thermostat housing for TPI gauge temp sensor STUDE55DOG Engine 0 08-14-2009 07:39 AM
Bouncing water temp gauge... rbomar Engine 7 05-21-2007 04:50 PM
Temp gauge grandprix601 Electrical 2 03-17-2004 08:45 AM
Wiring Stuart Warner Amp Meter Gauge hot rod jerry Electrical 2 06-29-2003 06:49 AM
New Gauge Wiring Chadman Electrical 1 04-08-2003 01:25 PM
