Wiring in an electric fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2005, 06:12 PM
I'm trying to install an electric fan out of a different pickup into my truck. Specifics really don't matter about which cars etc. I'm just trying to figure out how to add an electric fan to a vehicle without one stock. Can anyone here help me out?
I don't need it to activate at a certain temperature, just needs to turn on when the vehicle is on. I don't know if I need relays, or if I can just hook her up directly to the fuse box, etc...
Thanks for any help.
Old 03-17-2005, 07:19 PM
docvette's Avatar
Wiki Edits: 12
Fan
Doc here,
Electric Fans are high current devices, You should Always use a relay when installing one to keep from frying a harness.
If you just want it in "Run" all the time the best way to do it is get a relay that will handle the draw of the fan , whatever that might be, I think usual is 30 amps.
Locate and wire the Coil for the relay, one wire to a hard ground, and the other to about a 2 amp fuse, then to any source that is hot when the key is on. This is your control circuit.
Locate the Normally open Contact and the Center wiper of the relay, wire the center wiper to the Fan motor, and the normally open side to a properly rated fuse for the motor, then to any Battery source, or the harness side of the fusible link.
That's it. You will have a fan that runs when the key is "On" at all times.
Are you sure you don't want to temp control it?
In some cases running a fan continually, can cause over-cooling which is as bad for the engine as under-cooling...
You can add a manual switch by either adding a switch between the relay fuse and the switched 12 volt source to manually control the temps. Or between ground and the ground side of the relay coil...But this too has pitfalls, If you forget to turn it back on...you can overheat.
Hope it helps!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-17-2005, 11:01 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Check THIS out.
And THIS too!
Alan
54 Chevy Pickup
Wiring an electric fan w/relay horvath Electrical 46 11-20-2014 03:46 PM
electric fan wiring adrock430 Engine 4 02-28-2005 12:09 AM
Clutch Fan malibuman66 Engine 18 01-01-2005 10:09 AM
Wiring an electric fan dpjmw Electrical 7 08-04-2004 08:59 AM
Wiring An Electric Fan Using TWO Relays horvath Electrical 29 05-13-2004 11:57 AM
