wiring Ford to start engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2010, 08:38 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Looking for a very basic, diagram to start up engine. It is an in-dash ignition switch, (56 ford panel truck). It is a 460 with duraspark type distributor, (Proform), with an Accel 300 ignition module. It has the round canister style MSD coil. It will use the ford remote solonoid and stock ford starter. I do not have a neutral safety switch on car yet. I'm looking for something like, battery to solonoid, solonoid to ignition, solonoid to alternator, ignition switch to coil, ignition module, etc. I'm just looking for a safe wiring to start/stop engine to break it in, while also including stock 65 amp ford alternator. Ireland'schild sent me a book diagram a while back, but I'm really looking for a simpler diagram specific to my goal. ANY help, even hand drawn or written directions will help immensely.
Thanks,
James
Old 03-31-2010, 10:55 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi James,
Looking at the diagram you can see where the pos + battery & alternator wires go, & the battery cable on the other side of solenoid to the starter, now where the RED-BLU wire attaches to the solenoid, you'll want to wire in a momentary switch(push button) from that lug to the pos (hot) side of the solenoid, (that will engage the starter when pushed) Now the other lug on the solenoid where the BRN wire goes, you'll want to wire in a toggle switch from that lug to the pos + (hot) side of the solenoid, (this will be your on/off switch) You will also need to run a wire from that lug (where the BRN wire attaches) to the pos + side of the coil. I would also put a mechanical oil pressure gage in the hole where the oil pressure switch goes.
I hope this helps you, Good luck,
Rich
http://ww2.justanswer.com/uploads/se...ng_diagram.pdf
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
Calling All Ford Guys........ pulling engine, one shot??? biggeazy-e Engine 8 05-02-2007 10:28 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
