Wiring Fuel Pump?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2003, 05:38 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post Wiring Fuel Pump??
My EZ-Wire kit has a wire for the fuel pump ... it's also in the tail section. I don't get it -- isn't my fuel pump in the engine section? Also, I don't see ANY wire going to it.
Am I missing something? Or do they include that wire because many cars have electric fuel pumps?
I'm confused - help!
Thanks.
Alan Horvath
<a href="http://AlanHorvath.com/" target="_blank">http://AlanHorvath.com/</a>
Old 04-28-2003, 05:42 PM
dmorris1200's Avatar
doesn't play well with others
Post
If you are running an electric fuel pump it should be mounted as close to the tank as possible. Probably why the wire is in the rear harness. If you have a mechanical fuel pump then you shouldn't need to hook up that wire. Never have used one of those EZ Wire kits though.
BUILT FORD TOUGH
Old 04-28-2003, 06:22 PM
Post
Just count it as spare wire unless you want the electric fuel pump.
Trees
Old 04-29-2003, 03:33 AM
horvath's Avatar
Post
My fuel pump sits in the front/bottom/right side of the engine ... obviously it's a mechanical fuel pump, eh?
Okay - so I just have another spare wire then.
Thanks.
Alan
Old 04-29-2003, 07:23 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I replace the mechanical pumps on all my engines with the Carter 5psi electric pump, Summit #CRT-P4070, $57.95. I think there are several advantages. Gets rid of the stock pump that takes up valuable space @ front of engine, gets rid of ugliness in engine compartement, eliminates real danger of ruptured diaphgram and gas in the oil. This Carter pump is rotary, not a cheapie vibrator, and I have never had a failure in 20 years.
And yes, you install it at the tank and the wire goes to one lead on the pump, the other goes to ground, usually one of the pump mounting bracket bolts.
Old 04-30-2003, 05:06 PM
6567GTO's Avatar
Tire Fryer
Question
Willys - How quiet or noisy are those carters? I have a Holley Blue pump and man is that thing loud. Too bad the Carter doesn't make 6 or 7 lbs.
Old 05-01-2003, 07:19 AM
Wiki Edits: 21
Post
I never hear the pump - forget I even have it. Mine is mounted to the frame w/ rubber cushioned mounting bracket and is super quiet. I am not familiar with your 'blue' Holley but it may be a vibrating diaphragm style that are very noisy.
Why do you need 7psi? 5psi should give you more fuel than you could possibly handle on the street. Summit lists the 7psi version -
# CRT-P4594 $57.95. Same price as the 5psi.
