Wiring function differences between 700R4//4L60/4L60E? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2009, 12:36 PM
im converting a 66 gmc truck to auto and my first question is what is the difference between a 700r4 and 4L60 and 4L60e. then there is quite a few wires from harnesses which i need to know the purpose and how vital they are to make the trans perform correctly. can they be bi-passed or what do i need to do ?. thank you tony
Old 03-15-2009, 01:03 PM
CustomConspiracy's Avatar
Going auto
There is a lot to be learned at bowtieoverdrives.com. There is another company out there.....can't ever remember the name.....they have a TON of info....just google 700r4 and they will show up.
I don't know the difference. I wne t from a TH350 to a700R4 and it has worked out fine.
Old 03-15-2009, 01:09 PM
fast68's Avatar
likes chevy trucks & boobies
hi there,
all three are the same trans with different names in different years
700r4 was the first in 82
4L60E is the new name of them since around 93
E stands for electronic control
4L60 would be non electronic control,
IE an older 700r4
Old 03-15-2009, 01:13 PM
powerrodsmike's Avatar
Wiki Edits: 161
I changed the title of your thread to let folks what your question is.
Later, mikey
BE different....ACT normal.
Old 03-15-2009, 01:24 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Tony,
The 700 is an OD trans. for light duty Non computer controlled
The L60 is like a HD version of the 700 Non computer controlled
The L60E is computer controlled, need computer for pressures & shifts.
I'm sure someone else will chime in shortly with more information for you.
Rich
Old 03-15-2009, 10:23 PM
700r4/ 4L60/4L60e
how can i detemine which one i actually have between the three models. thanks tony.
Old 03-16-2009, 03:58 AM
SSedan64's Avatar
Here's a good 700R4/4L60 Tip sheet.> http://www.transmissioncenter.net/700r4.htm
4L60E will have a plug like this link from Crosley's photo album.>>
http://www.hotrodders.com/gallery/sh...hp/photo/37081
700R4/4L60 has a 4-Pin plug.
Old 03-16-2009, 09:58 AM
wiring 700r4
thank you that helps alot.. im sure ill need further assistance. tony!
Old 03-16-2009, 08:03 PM
airworld2's Avatar
4l60
Originally Posted by richard stewart 3rd
Hi Tony,
Rich
they all share the same operation function in basic form,and they all have the same clutch and band the difference is the way the units are shifted
700 was re named 4l60 shifts where determined via t/v cable and governor they used computer for lock up only
in 93 4l60e was introduced using shift solenoids and pcm (computer) for up shifts
Brake light switch wiring... 38 special Electrical 10 09-15-2007 06:54 AM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 02:28 AM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
WIRING 2000 S-10 CONVERTION Luap Engine 0 12-09-2002 04:01 PM
