wiring Gm power seats - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2007, 08:39 PM
Last journal entry: Rat rod phase - on the road -
HI I'm fitting a pair of power leather seats from an 89 Eldorado to my 38 chevy 2 door hump back - i should have stayed simple but the price was right - and the leather was super sweet - the passenger side is cake - hook up red and to power and black to ground - everything works great - -- The drivers seat (the one the means something) has a "brain box" in the harness - The schematic in the factory service manual doesn't spell it out - I'm assuming its the memory seat controls . does anyone have any EXP with this type of transplant - Thanks Matt
Old 12-06-2007, 10:06 PM
correction - 98 eldo !!
flipped my numbers they are from a 98
Old 12-07-2007, 07:43 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Hi: I'm going to move your post to Electrical. I think you'll get more and better answers there.
Dan
Old 12-08-2007, 07:18 AM
bentwings's Avatar
bentwings
The GM seats I'm installing in a customer car only have 2 wires one is ground and one is hot key on. There is some kind of "box" but I think it is just a selector for the switches as the switch wires all run to it. 30 amp fuse.
Old 12-08-2007, 10:00 AM
Thanks -
thanks - These seats had the "memory option . its actualy a computer with serial comunications with the memory selector -- all of the flexible shafts have position sensors on them and they feed back to the computer box (about 6 x 8 inches clipped to the springs of the seat - . i cliped out all the sensors and the cumputer box - using the the passenger seat as a guid i used clip leads from the switch to the motors and i can make everything to work so im just goign to wire up a new harness that mirrors the passenger sid set up . that way i just need the hot and ground in - the eldo scemat has them fed by a 30 amp breaker ----Id be interested in anything anyone else has done with this sort of thing - Next up i need to do the seat heaters -
Old 12-08-2007, 11:31 PM
bentwings's Avatar
bentwings
Sounds like a good plan.
gm headlight switch wiring, HELP!!! rjfscorpio711 Electrical 7 11-19-2007 07:05 PM
wiring a 3 switch kit for power windows?? doncase Electrical 7 06-11-2007 09:24 AM
I need help about GM horns..wiring aftermarket horn GMCANYON Electrical 5 04-27-2007 08:11 PM
Power Seats MI2600 Electrical 4 10-06-2005 04:55 AM
wiper motor wiring - gm column -- HELP PLEASE!! gtofloyd Electrical 2 11-11-2003 11:10 PM
