Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wiring gone bad (terribly bad)
Old 04-24-2006, 05:53 PM
matt167 matt167 is online now
Wiki Edits: 31
u wired the starter wrong. the is the starter switch your thinking of on the passanger side fenderwell? if so it's the starter relay, you probably smoked it because of that, and got stuck. you probably need a new 1.
