Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wiring gone bad (terribly bad)
Old 04-24-2006, 06:19 PM
65Mustang289HIPO 65Mustang289HIPO is offline
Well ... the starter is wired correctly to the starter switch (starter relay as you said) but I wired the slternator directly to the switch/relay which caused the problem (the alternator suppling power directly to the relay with no way of cutting it off ... hence the fact that the engine would not turn of without me manually pulling power to the damn thing)
What I want to know is how much of my electrical system might I have fried and what should I check to see if I need to replace.
