Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wiring gone bad (terribly bad)
Old 04-24-2006, 06:29 PM
matt167 matt167 is offline
Wiki Edits: 31
any wires that look bubbully or burnt. there are 2 posts for small wire to go on the relay, there is a start terminal labeled S connected to the red wire and a L ( I think ) that is the black wire. how did u cross those wires? if u cross the red wire to the pos side of the battery, it will turn the motor over, so from what I'm getting, you hooked the alt direct to this?
