Originally Posted by matt167
any wires that look bubbully or burnt. there are 2 posts for small wire to go on the relay, there is a start terminal labeled S connected to the red wire and a L ( I think ) that is the black wire. how did u cross those wires? if u cross the red wire to the pos side of the battery, it will turn the motor over, so from what I'm getting, you hooked the alt direct to this?
I hooked the alternator directly to the Big post where the battery is directly connected!
Also thanks for the solenoid test Doc....Now if I can just get ahold of a voltage meter to do the test....time to go looking in the closet (of my roomate)
