Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wiring Guide for Electronic Ignition Module Install (Igniter)
Old 01-18-2013, 12:46 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
If you can't identify the distributor and look it up, looking at the OEM wiring colors, looking down on it with the three connectors at 12 o'clock and one around the corner to the left, I would connect the black/yellow on the center spade, the blue/white to the left spade, these appear to be correct. That leaves the green and black, if I had to make a choice, I'd put the green around the side where it calls for blue, and the black where the brown goes, to the right of the black/yellow. See if it'll start. If not, swap the last two... Can't get any more back yard than that!
Semper Fi
