Wiring Guide for Electronic Ignition Module Install (Igniter) - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2013, 09:21 PM
'89 Honda Civic
I'm replacing the Electronic Ignition Module (Honda Part Number: Igniter unit kit 06302-PT2-000) inside the distributor.
I do not know how to reconnect the wires. The Igniter has 4 prongs (see pic).
http://i1303.photobucket.com/albums/...pscd5f4aee.jpg
I have 4 wires: 1.Green 2.Black 3.Black w/yellow stripe 4.White w/blue stripe (see pic)
http://i1303.photobucket.com/albums/...ps7997b756.jpg
http://i1303.photobucket.com/albums/...psb5f48676.jpg
These colors do not match the colors in the Honda manual. I read on other forums this probably means the distributor is an after-market.
I need to know which wire connects to which prong. I have searched the web and repair manuals. Does anyone have any idea?
Old 01-17-2013, 11:46 PM
68NovaSS's Avatar
Wiki Edits: 9
If you can't identify the distributor and look it up, looking at the OEM wiring colors, looking down on it with the three connectors at 12 o'clock and one around the corner to the left, I would connect the black/yellow on the center spade, the blue/white to the left spade, these appear to be correct. That leaves the green and black, if I had to make a choice, I'd put the green around the side where it calls for blue, and the black where the brown goes, to the right of the black/yellow. See if it'll start. If not, swap the last two... Can't get any more back yard than that!
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 01-18-2013, 01:24 PM
68NovaSS's Avatar
Wiki Edits: 9
Try this link to see what those wires connect to and what they should test read.
Relocating Ignitor (ICU / ICM) - Honda-Tech
I read the blue wire is tach, white is neg -, blk/yellow is ign.
Old 01-18-2013, 05:18 PM
Thanks
Thank you. I was pleased that was the order that I had them in. Unfortunately, it still didn't start. I checked and I don't have a spark. I am going to get a mechanic to help me at this point. Thank you so much for your help. ~Lacie
Old 01-19-2013, 11:38 AM
T-bucket23's Avatar
Wiki Edits: 26
I have more than once seen a bad cap on those keep them from starting and running.
Chet
Old 01-19-2013, 11:49 AM
Thanks so much!
I really want to thank you both for all the help/advice. I'm was really hoping I could get it going myself and I probably could if I had more time, more knowledge, and the proper tools. Thanks!
Wiring without ECM electronic control module dyanskey Electrical 3 04-01-2012 01:49 PM
Mallory 8548201 electronic module issues STUDE55DOG Electrical 0 12-20-2011 05:48 PM
electronic spark control module 64stepside86tbi Electrical 8 11-19-2010 07:31 PM
Ignition control module wiring kane583 Electrical 2 07-14-2006 01:12 AM
Electronic Module or Coil. DTL504 Engine 4 04-20-2004 09:18 PM
