wiring harbor freight air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2011, 11:54 AM
I'm going to pick up the 60 gal 5hp harbor freight air compressor. Manual says it needs a 40 amp circuit breaker. I have a 220 line with a 50 amp 4 wires 2 black 1 red 1 green. it had been powering a electric stove in garage when there was a duplex in garage.
Will this wire up to the air compressor without any other changes? Their instructions say its a 4 wire set up.
Keep in mind i'm new to this wiring.
Old 10-11-2011, 01:13 PM
T-bucket23's Avatar
Wiki Edits: 26
You should call an electrician if you are not 100% sure of what you are doing. You will need to at a minimum change the breaker. If the wiring and other components in the compressor at rated for 40 amps and you are on a 50 amp breaker, the compressor wiring will melt and burn before the breaker trips.
Chet
Old 10-11-2011, 03:18 PM
You are talking about the US General? There has been a lot of discussion about those compressors and how well they compare to a lot of other brands sold at various places. Since the last time I was in a discussion here about them I helped a friend of mine who runs a dairy farm install one to replace an old Brunner compressor from the 1950's since he had updated his equipment and needed a more reliable air supply. The unit was only supposed to be for occasional use, about what one might expect in a home shop, but more equipment was added and this thing has been seeing almost constant duty for several months now which it is doing without so much as a whimper! For what it cost it has, IMO, far exceeded what should be expected of it and so far shows no signs of giving up. Just thought you might like to know that!
I agree that the best advice on the wiring is what T-Bucket already said.
Old 10-11-2011, 05:40 PM
h.f air comp.
ive been doing elect. for a long time 30 yrs. never heard of a 4 wire air comp. unless its 3 ph still dont need all 4 to make it run # 8 romex copp. is good for 40 amps what kind of wire do you have alum. our copp. mine is 7 1/2 hp 50 amp breaker never failed me knock on wood 2 hots and ground is all you need
Old 10-11-2011, 09:21 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Updated electrical code
The 4 wire system is an update to the electrical code..One wire the green is attached to the frame of the equipment to provide a positive ground. the white is the neutral and goes to the neutral at the switch and the hots which are red and black go the contactors of the switch..A lot of the new homes and buildings have 4 wire systems these days..Still have an electrician come in if you are not sure on wire sizing and such..
Sam
Old 10-14-2011, 05:24 PM
Old Fool's Avatar
The circuit breaker only protects the wiring to the device, not the device.
It is sized for the wire connected to the breaker, not the wire size of the device.
The device may have its own protective device such as a motor overload breaker.
Think of it this way, a house is wired with 12/2wg and has 20 amp breakers for the receptacles. You almost always plug in devices that are not 20 amp loads. You never worry about the wire on the toaster melting because the breaker was to big for the cord on the toaster.
Harbor Freight Compressor matt167 Garage - Tools 13 09-28-2012 08:12 AM
Harbor Freight eloc431962 Hotrodders' Lounge 27 11-05-2009 11:13 AM
i need a cheap beginner welder and air compressor. harbor freight? jagarcia05 Garage - Tools 64 07-13-2009 09:18 PM
Harbor Freight TIG oldred Garage - Tools 54 02-22-2009 05:00 PM
Harbor Freight Coupon 3100 Special Garage - Tools 0 10-19-2005 04:08 PM
