Wiring harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2008, 10:46 AM
79z28's Avatar
79 Camaro z28
Last journal entry: rear wiring harness off
Wiring harness
I'm doing a complete resto on my 79 Camaro z28 and will most likely go with a EZ harness. This might be a stupid question but does the wiring harness come with power windows, power locks? I would think you can specify when you order the harness if you want those options right? I'm going to buy new doors just wasn't sure if i should keep the wires in the existing doors. Thanks
Old 04-07-2008, 02:53 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The Painless chassis wiring harness has the items you asked about plus others.
Good luck,
Rich
Old 04-07-2008, 07:48 PM
life is a temporary assignment
Yes EZ wire has what you are asking.The 21 circuit has it.I have used it on all of my car's.EZ wire is a very nice kit.I buy all of my kit's on ebay.Just got a kit two day's ago.
Old 04-07-2008, 08:22 PM
79z28's Avatar
79 Camaro z28
wiring harness
I'm not looking to buy a harness just yet. I've asked about harnesses and it's either painless or EZ. So was i right about when i go to order to ask for power locks, window wiring for the doors or will it just come with the harness? Also is there anything on the harness i took out last night that i should save? Thanks for the advice!
Old 04-07-2008, 08:32 PM
this is the one I just got off ebay.
Old 04-07-2008, 11:00 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I used EZ wire on an older car, a '68 Nova. One thing I was glad I did was save the half moon connector on the chassis side out of the steering column. The EZ wire kit connector was different and had no adapter that was even similar, it was a useful reference for matching wire color for parking and turn signal wiring. A newer vehicle kit may contain the correct connector. Just a thought that might help you later on.
It all looks pretty intimidating right now, but it's not that bad, good luck.
Semper Fi
Wiring Harness Information MrBrightside Electrical 12 12-18-2007 06:58 AM
POWER accesory wiring harness 91vette Electrical 13 04-11-2006 05:21 PM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
ford wiring harness akm Electrical 6 03-13-2004 10:25 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
