Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wiring Harness
Thread: Wiring Harness
Old 07-18-2011, 01:55 PM
RippinRon's Avatar
RippinRon RippinRon is offline
The EEC harness is separate from the the rest. It has three parts the main, the injector and 02 sensor section. The original distributor controls the timing with the eec. The fuel pump is controlled with the eec but goes through the oil pressure switch and only stays running with oil pressure.
ID:	56928   Click image for larger version
ID:	56929   Click image for larger version
