Wiring Harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2009, 02:49 PM
SBC-Torque's Avatar
Wiring Harness
I have a 1979 chevrolet 1/2 ton silverado
the guy that had it before me really butchered the stereo wiring,
so i went and picked up a new wiring harness for it, and a deck, 6X9s etc,
but i cant figure out where the harness plugs into? is it just above the fuse box? or where. Some help would be appreciated, thanks.
Old 12-19-2009, 07:00 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
I don't recall the stereo wires on my 76 or 79 Chevy pickups "plugging in" anywhere.
You'll need a wiring diagram to figure it out.
Old 12-21-2009, 09:03 AM
What you probably grabbed was a harness to hook an aftermarket deck into the stock stereo harness. You will have to get the stock wiring diagram to find which colour wire does what for stock.
Old 12-21-2009, 07:20 PM
123pugsy's Avatar
Wiki Edits: 29
There should be a grey, yellow and black wire.
Black is for ground of course and the yellow and grey will be for key on power and headlights on power. Just take a tester to figure out which is which.
Old 12-27-2009, 09:18 AM
The stock 3-wire plug should be just hanging up under the dash near the radio. You can usually look up under the dash and see it. You will have to run all the speaker wiring separately, unless your truck had the stereo radio option. Even if it had the option, the speaker wires are probably fairly small gauge.
Bruce
Building a new Dodge wiring harness, need help DaSouthWon Electrical 3 03-01-2009 05:39 PM
POWER accesory wiring harness 91vette Electrical 13 04-11-2006 05:21 PM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
ford wiring harness akm Electrical 6 03-13-2004 10:25 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
