wiring harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 07:19 AM
Last journal entry: chevelle
wiring harness
what is a good company to buy a wiring harness from. I going to rewire my nash metropolitan.
Old 01-20-2011, 07:26 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
have you tried here?
"Wiring Harness"
Old 01-20-2011, 07:48 AM
malc's Avatar
Born To Be Mild
Rebelwire seem to be quite versatile.
Old 01-20-2011, 04:43 PM
EOD Guy's Avatar
There is a sticky at the beginning, that has a ton of info and opinions about many diff wiring harnesses.
Old 01-20-2011, 05:01 PM
cal1320's Avatar
I used EZ wire. No complaints.
Old 01-20-2011, 06:06 PM
Joe G's Avatar
Registered user
Is it stock? If it is, I would recommend a reproduction harness. They cost more, but you can install them in 1/10th the time, and there is no guesswork as to how to hook up the wires to your factory switches and components.
For stock harnesses on a car like yours, I have had good luck with Rhode Island Wiring.
Hope this helps....
Old 01-20-2011, 08:56 PM
Commanderkewl's Avatar
Time traveler stuck here...
I've got one to add to this bit. I too, have a wiring harness I bought .. Painless..looks pretty much like it too since it's still in the box... Give me a few months to get rid of the broken leg cast and get back out in the garage.. (lots to do such as put the body back down onto the frame..etcetc.Lots to do..
So anyhow, the kit has a lot of regular type of connectors. What would be a reccomendation for upgrading the connectors making them better and looking custom. You guys have been through many of these things and the little shrink tubing, better wire looms, rails, whatever ideas you have to make the wiring look like it belongs (where you see it ) and where you can't see it .. Hidden from plain sight ..
Did I make sense about this?
Not trying to hijack, just seems it's as important as the type of wire loom system as the execution..
We've all seen some really nice rides out there that when you open the hood it looks like we see inside a deranged crazy fodder.. Wait a second, that's me!
Thanks in advance.
Mikey aka CommanderKewl
5.0l Wiring Harness 5.0Falcon Electrical 8 11-12-2010 07:57 AM
L98 TPI wiring harness Roadkill58 Engine 2 05-10-2009 02:17 AM
Wiring harness Ford Wagon Electrical 4 10-02-2008 08:03 AM
Wiring Harness Cliff Gemeroy Electrical 1 02-19-2006 03:58 PM
Wiring Harness Olrowdy Introduce Yourself 1 11-14-2004 03:19 PM
