Wiring Harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2011, 12:10 PM
Mac88's Avatar
"Drive It Until It Breaks"
Wiring Harness
I unplugged the ECC wiring harness today. The car turns over, but wont start. I'm pretty sure it's because the ECC controls the fuel pump, but now the ECC has been removed. I have an electric fuel pump here that I think will fix that. My question however is this, the distributor was factory, with a connection to the ECC harness. No that the ECC is unplugged, how will that effect?
Old 07-18-2011, 12:23 PM
RippinRon's Avatar
What are you working on?
Old 07-18-2011, 12:28 PM
Mac88's Avatar
Re
88 Mustang GT
I bought the car from someone who started working on it and stopped. He was running a carb, had toggle swith ignition, push button start, etc., but wires are everywhere. There was a MSD box half way connected, he said there was a electric fuel pump back there, just not connected. So I completely removed the harness to clean up the engine bay a little. The plan was to switch to a 351W later this year anyways, but I still want the car running, in the event i try to sell the 302. Any advice on how to started cleaning up this wiring nightmare?
Old 07-18-2011, 12:55 PM
RippinRon's Avatar
The EEC harness is separate from the the rest. It has three parts the main, the injector and 02 sensor section. The original distributor controls the timing with the eec. The fuel pump is controlled with the eec but goes through the oil pressure switch and only stays running with oil pressure.
ID:	56928   Click image for larger version
ID:	56929   Click image for larger version
Old 07-18-2011, 01:02 PM
Mac88's Avatar
So basically, I need to change out the distributor with one not needing the EEC? I'm going to post some pictures of what I'm trying to sort through. I just want to get the car running so I can get it to a shop and let someone go through all this wiring and tell me what's what.
ID:	56931   Click image for larger version
ID:	56932   Click image for larger version
Old 07-18-2011, 01:31 PM
RippinRon's Avatar
got to autozones website and join and you can find repair guides and wiring diagrams. Break it down to what you need, ignition etc. Save yourself some money and figure it out.
Old 07-18-2011, 01:33 PM
Mac88's Avatar
Re
Thanks! I'm learning as I go, and I'm always looking to save money.
Old 07-18-2011, 02:54 PM
Mac88's Avatar
Re
I went down to autozone and picked up a new ignition switch. Its amazing how much simplier everything looks in there now without all those wirres and toggles. Now I have to figure out this distributor. Is there a specific vacuum or mechanical distributor I need to look for, or will any 302 distributor work?
Old 07-18-2011, 07:19 PM
LATECH's Avatar
Go to the u pull it yard and get the complete dura spark 2 system off of a 76-77 ish 5.0 . The dizzy will have the vacuum can and the module will have a blue grommet. Get the coil and bracket too.Look the harness over well, most of the duraspark is pretty easy to see. The only place you should need to clip it will be at the red wire for the power from the ignition, clip it on the side closest to the ignition switch( keeping the connector intact) as you will need the white wire to hook to the starter solenoid for the Ignition bypass(during starting).
You can power it with the output from the EEC 4 relay and from the correct starter solenoid.
If you are running a msd then follow there instructions using the output wire from the EEC 4 relay (blue w/red) for the white wire on the msd box (ignition switch on/off circuit)
Sounds like you have a fuel pump on the motor so ignore fule pump wiring , change the sending unit to a non efi sender to eliminate the fuel pump being there as it can cause a starvation problem.
Old 07-18-2011, 07:22 PM
LATECH's Avatar
This might help:
http://www.webpages.charter.net/1bad6t/duraspark.html
Arrrrgh linkie no workie.
Just google duraspark 2 and youll get a buttload of info
Old 07-18-2011, 07:26 PM
LATECH's Avatar
I have done conversions like this many times, I allways have a big pile of wires left over.
I am doing a dodge dakota right now, it's looking good, only have to weave the cooling fan setup in the loom and its time to tape it up, then Cover it with a convoluted wrap.
I'll keep an eye on your progress
Old 07-18-2011, 07:40 PM
Mac88's Avatar
Re
latech
I sent you a pm
Old 07-19-2011, 01:21 PM
Mac88's Avatar
Duraspark
No luck at the pull yard. I'm going to autozone to buy one now. I know I need the steel gear, but does it make a difference whether I get one vac or two? Should I still buy a coil, or just use the factory coil that's on the car now?
Old 07-19-2011, 03:57 PM
LATECH's Avatar
Get the single vac dizzy, and a new coil
I saw where napa sells the resistor wire you will need, you could also use a ceramic ballast resistor.
Old 07-19-2011, 05:04 PM
LATECH's Avatar
Dont forget the ignition module (box)
L98 TPI wiring harness Roadkill58 Engine 2 05-10-2009 02:17 AM
L98 TPI wiring harness Roadkill58 Electrical 0 05-09-2009 08:08 PM
Wiring harness 79z28 Electrical 5 04-07-2008 11:00 PM
Wiring harness ken demer Electrical 4 08-23-2006 08:37 AM
LT! Wiring Harness JimmyL Electrical 3 10-02-2003 08:00 PM
