We're winning the case!
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 10-29-2005, 06:58 PM
jgrant jgrant is offline
Wiring headlight circuits
Hi,
I am going the wiring myself on my Triumph TR6. The original harness was shot, so I decided to wire the whole thing myself. So far I have the car completely done, it works and all is well.
I wired the headlight circuit (headlights as well as the driving lights) hot all the time. I mean, I have a switch, relays, the works. I wired this so that the ignition switch does NOT have to be ON in order for the lights to work if the light switch is pulled.
Is this the proper way to wire this, or do you guys have that circuit on a switched hot lead?
joe
Old 10-29-2005, 07:01 PM
docvette's Avatar
docvette docvette is offline
docvette's barnstar
Wiki editor
Last wiki edit: Rebuild an alternator
Wiki Edits: 12
Doc here,
Sounds all good to me..the builder doesn't even put headlights on a switched circuit..if your using relays, then your one up over stock
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Wiring headlight circuits"
Painless wiring harness question Big Geek Electrical 9 02-28-2005 03:30 PM
kig bee headlight wiring grapro Hotrodders' Lounge 1 05-24-2004 03:36 PM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
