wiring horns? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 03:13 PM
tjn tjn is offline
tjn/56nomad
wiring horns?
Guys, is their a simple wiring diagram for a set of horns? Many thanks, TJN/56NOMAD
Old 08-11-2012, 04:55 PM
EOD Guy's Avatar
Do you want to use the column horn button or a sepertae switch with a relay?
Old 08-11-2012, 09:47 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
See the attached diagram.
vicrod
Old 08-11-2012, 10:41 PM
SinistrV6's Avatar
valve monkey
I'm following this thread as well. The diagram doesn't seem to match what I have. My EZ Wiring harness has one hot wire for the horn. My dual horns (scavenged from an '03 Trailblazer) have two wires (green and black). Am I missing something?
Thanks,
Richard
Old 08-12-2012, 04:39 AM
EOD Guy's Avatar
This is how mine is wired
Old 08-12-2012, 06:24 AM
SinistrV6's Avatar
valve monkey
Thanks EOD Guy. I cut the pigtail on the Trailblazer horns in the wrecking yard and got it too. I assumed the black was a ground but I only have a short section of the factory wiring connected to them.
No Horns Tom1987 Electrical 9 02-21-2011 10:10 PM
help on installing two horns vanislander Electrical 8 12-29-2008 01:01 AM
2 1/2 Rams horns. 49willard Engine 6 08-06-2008 08:13 PM
How do I wire up my horns? cpthowdy Electrical 6 07-13-2008 11:11 PM
I need help about GM horns..wiring aftermarket horn GMCANYON Electrical 5 04-27-2007 09:11 PM
