wiring ignition switch in a 54 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2009, 09:10 PM
*** Please post solutions ***
54 chevy special 150 original 6v point system
Want to wire in a conventional universal ignition switch
http://www.summitracing.com/parts/PRF-80529/
http://static.summitracing.com/globa.../prf-80529.pdf
All wiring diagrams I find incorporate a seperate starter button.
This should be really simple but I'm stumped...
here is a link to the stock wiring:
http://chevy.oldcarmanualproject.com...54ctsm1202.pdf
Please paint a picture as I do not do schematic well.
Thanx in advance
-=Fred=-
Old 11-29-2009, 10:45 PM
Wiki Edits: 31
why would you want an ugly ignition switch when you don't have to? www.chevsofthe40s.com sells reproductions of the original '53/'54 switch. you would need the switch and a tumbler/ key but togther would cost less than that painless switch.. http://www.chevsofthe40s.com/detail/...INAL_FOR_.html
if you have an original switch that worked with 6v, it will still work with 12v and you won't need to worry about it
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
Ignition problem 1961 Chevy truck truckboy61 Electrical 1 06-10-2009 08:08 PM
wiring my 54 ford p/u william r plise Electrical 4 10-06-2006 04:38 PM
1970 ford trk ignition switch wiring mike simpson Electrical 1 01-25-2006 10:16 PM
Ignition switch wiring ??? primerat Electrical 2 11-10-2005 05:09 PM
