wiring kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2005, 12:12 PM
New Member
wiring kits
I am going to rewire my 55 chevy, which kits do you guys find to be the best?
Is there a kit where the wires are pre-cut with terminals? I have heard of Ron Francis, Autowire and Rhode Island wiring.
Thanks,
Bill
New York
Old 07-19-2005, 12:31 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
I haven't gotten that far in my project but purchased ez-wiring kit,www.ezwiring.com
A few others have too. Seemed to be satisfied with results. Horvath purchased one of these kits rewired his whole truck.
Old 07-19-2005, 12:34 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have not seen an aftermarket harness that is precut and terminated..the makers of those have no clue as to what kind of car it will wind up in or how the end user will route the wireing..
OMT
Old 07-20-2005, 03:34 PM
a67tempest455's Avatar
I have used painless wiring on three projects, a 78 trans am, a 82 CJ-7 Jeep, and a 73 VW "THING" and helped a friend put one in a 56 chevy sedan delievery. I was always very pleased with the quality and ease of installation. Personally I dont see how the preterminated kits will create a clean installation, the manufacturer doesn't know how you want to route the wires or what equipment you are running. Painless makes a kit specifically for the shoeboxes, you may want too check them out. www.painlessperformance.com
Old 07-20-2005, 08:19 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
I bought an EZ wiring kit for my 1955 2nd series chevy truck. I have not installed it yet but it looks like it will work fine and only cost $165.
Old 07-21-2005, 11:30 AM
Painless.....complete instructions, wire labeled every foot or so, tech support without an attitude problem. Have wired several with the various painless products, & still waiting to have a bad experience
Old 07-21-2005, 12:13 PM
302 Z28's Avatar
Pinless has a quality product, but a little pricey. You can get more bang for your buck if you do a little research. Once you start investigating you will find that only a few use the quality GXL wire. That is the same wire GM uses for underhood use.
GXL wire - thin wall high temp insulation
TXL wire - extra thin wall high temp insulation
Just about every kit nowadays has the wire labeled every foot or so. EZ Wiring IMO has one of the best and easiest to use kits on the market.
Vince
Old 07-21-2005, 12:51 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
I am just finishing up the re wire on my 55 1st series with a It's A Snap. The hardest part of any of these kits is placing the wires where you want to make the home runs so they will be out of sight!
Just take one circuit at a time or all the circuits from the front and then the rear, you will find our in the end that the only problem was "getting Started" !!
Old 07-21-2005, 01:40 PM
Wiki Edits: 49
Stay away from Ron Francis kits. His stuff is nice but the circuit panel contains a proprietary circuit card and no one but Ron Francis can fix it.
I used an "It's a Snap" harness on my 53 Pickup and it worked out very well. Wires labeled every foot, very compact circuit box and inexpensive when compared to the competition.
Old 07-21-2005, 02:59 PM
Thanks,
Bill
New York
Try www.americanautowire.com or 1-800-482-wire as they show a specific kit for tri 5 chevs.
Old 07-22-2005, 09:36 AM
New Member
Thanks and fusable link question.
Thank you to everyone for their input. I have some homework to do! I have one more question. what are your thoughts on fusable links in harnesses?
Thanks again,
Bill
Old 07-22-2005, 02:35 PM
solidaxel's Avatar
iN THE HARNESS OR AT THE STARTER!
Old 07-23-2005, 11:12 AM
gator412's Avatar
Go to http://www.madelectrical.com/ and check out this site. It has really good info. I bought several kits from him to help my 1955 2nd series truck electrical system perform at its peak.
Old 07-25-2005, 04:28 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
I did the EZ-Wire kit and had a blast with it. Much less money than Painless, too. You can check out all my notes and photos HERE
Fusible links are the way to go, man. I didn't understand them at first, now I swear by 'em ... read all I learned HERE
Alan
54 Chevy Pickup
Old 07-26-2005, 10:22 AM
New Member
Thanks guys, I really appreciate your knowledge!
Bill
N.Y.
Wiring Kits crazygutgut Electrical 40 12-15-2005 08:49 AM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 06:18 AM
Painless wiring kits I_3putt Electrical 17 10-27-2003 03:39 PM
??I NEED HELP WIRING 2000 S-10 CONVERSION Luap Engine 0 12-09-2002 05:43 PM
EZ WIRING POWER WINDOW KITS little marine Interior 1 12-11-2001 06:20 PM
