Wiring Lincoln LS Seats - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2006, 09:53 PM
I picked up a set of '06 Lincoln LS buckets and am unsure how to wire them. Driver's seat is 8-way power, 2 setting memory, heated and cooled, side airbag. Passenger's seat is 6-way power, heated and cooled, side airbag. All switches except memory are on the seats. There are two plugs with multiple wires. I'm sure some circuits are un-necessary. Any suggestions as to where I might locate a wiring diagram?
Old 06-22-2006, 12:21 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moving to electrical..
Sam
Old 06-22-2006, 05:20 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
What's it going in..and what features do you want to use?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-25-2006, 12:05 AM
The '06 LS seats are controlled by a multiplexed network between the driver's seat module and the driver's door module, making the usual minor adaptations found in power seat wiring much more difficult. I won't say it's impossible but, you have your work cut out for you to say the least.
I can easily hook you up with the wiring schematic ...the heat/cool functions are less complicated and need only B+, KPWR, and of course the switches that are located in each front door!!!!
If you want the schematics just PM me your email address
Electric wiring on Lincoln WardellW Electrical 3 07-14-2009 09:05 PM
Wiring Power Seats horvath Electrical 18 10-18-2008 12:17 PM
What Kind of paint is on a Lincoln LS viperACR Body - Exterior 5 03-26-2004 06:57 PM
Lincoln LS Hydraulic Clutch cvaselaar Transmission - Rearend 0 10-10-2003 08:35 AM
1993 lincoln wiring harness 70sum Electrical 5 01-03-2003 04:51 AM
