wiring a new aooogah horn in 1927 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2010, 12:30 PM
Sorry, I posted this earlier in the wrong area! I am trying to install a aooogah horn in my 1927 Ford Roadster. The car has an aftermarket wiring harness with a fuse panel that has a connection for the car horn and sitting behind the connection is a 40amp relay that clicks when you ground a tester light to the car and touch the terminal on the panel. Can I take a wire from that terminal to my push button switch I am using and then take another wire from the other side of the switch to the positive side of the horn and then groung the negative side of the horn to the frame of the car? This is what I had planned to do until I began to read another forum, that says to run ground to your switch. I had purchased a relay to install, until I found the wiring harness already has one. Please advise for the proper installation. Thanks for all the help, dandeto
Old 09-17-2010, 09:55 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
negative
The horn button controls the ground side relay coil. When you press the button it closes a contact which completes the circuit to ground thus energizing the coil of the relay. The other side of the coil is fused + at all times.
The contacts of the relay close whenever the button is pressed completing the + circuit to the horn.
vicrod
Old 09-17-2010, 02:46 PM
35terraplane's Avatar
horn
I think fords were pos. ground, not neg. so you would hook everything up, so to speak backwards.
Old 09-21-2010, 12:45 PM
Aoogah horn now working
Thank you for the information. Once you take a good look at it, it works well. I ran a positive wire to the horn and took my wire from my 40amp relay and ran that to the push button switch and then ran the other side of the switch to ground and everything works great. Thanks dandeto
Old 09-21-2010, 05:58 PM
Cape Cod Bob's Avatar
If u hook it up backwards does it go hagooa ?
Old 09-21-2010, 10:38 PM
horn
It might even do more. When you hook the Positive terminal of your battery to ground, and the Negative is hot, to most people that would be backwards, of course some people dom't know positive from negative.
Later 35terraplane
51 ford wiring Granddad's51 Electrical 3 04-28-2009 05:14 AM
1952 Ford Victoria wiring diagram nickeldimerods Electrical 0 05-22-2008 02:39 PM
1983 Ford F-150 Pick-Up Truck Wiring Diagram wojy37 Electrical 4 01-05-2003 09:35 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
wiring diagram for a ford F-100, 1970 musmly Electrical 2 05-27-2002 09:50 PM
