Wiring New Port wiper motor to GM column - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2007, 11:51 AM
bnewsom's Avatar
Last journal entry: more finished pics
I've got a mid 80's tilt column out of a Pontiac wagon in my 52 Chevy. The column is set up with wiper controls on the turn signal stalk. Has anyone hooked up a GM column wiper switch to New Port engineering wiper motor? The wipers came with a simple off/low/high switch but would like to use the column switch and set it up to work with the delay as well. Any help would be appreciated.
Bob
Old 08-25-2007, 06:43 PM
docvette's Avatar
Wiki Edits: 12
Bob
Doc here,
Your best Bet is contact the company..
you need to CONFIRM the SPEED control wires are at ground potential, and see IF a delay module is required..the rest can be controlled from RELAY switching from the GM stalk Switch.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
36 Ford Banjo wheel to a late GM column Django Interior 8 01-07-2003 07:52 AM
GM column in a '62 Falcon graig Electrical 0 01-07-2003 02:44 AM
GM wiper motor color codes. JOHND. Electrical 0 12-10-2002 06:03 AM
Steering Column wiring fred56 Electrical 6 12-07-2002 10:16 AM
Early GM column shifter & 700r4 56xpresso Transmission - Rearend 2 07-17-2002 02:56 AM
