Wiring a One Wire GM Alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2011, 04:53 PM
Sweet-34's Avatar
Lost In The 50's
I'm installing a one wire 120 amp chrome alternator on my engine. I have a one wire alternator on my 327 Chevrolet now. The previous owner ran the one wire (16 gauge) into the wiring harness going under the dash. Can't I just cut that wire off and end it and put an 8 gauge wire from the alternator post to the large post on the starter coming from the battery in the rear?
Thanks~
Old 06-14-2011, 05:14 PM
T-bucket23's Avatar
Wiki Edits: 26
I don't like 1 wires but yes that would work. Basically the large stud on the alternator needs to be directly connected to the positive battery source.
Chet
Old 06-14-2011, 06:30 PM
Overdriv's Avatar
That will work as long as your power distribution comes from the same solenoid post.
Old 06-14-2011, 06:57 PM
Sweet-34's Avatar
Lost In The 50's
One Wire Alt
Please explain what you mean!!!!
Old 06-14-2011, 09:05 PM
Overdriv's Avatar
Where is your power to the dash coming from if you abandon the 16Ga wire you mentioned in your 1st post?
I have no idea what you are working on, but you will need to power the fuse box, ignition, acc, etc.
Putting the alternator output to the starter solenoid is ok as long as there is another large gauge wire coming from it to power everything.
Give us a few more details on what you are working on.
Old 06-15-2011, 05:12 AM
Sweet-34's Avatar
Lost In The 50's
I'm working on a '49 Merc Sled with a 327 c.i. motor and a 350 Turbo transmission. Thanks.......Ron
Old 06-15-2011, 06:14 AM
SSedan64's Avatar
Above Info will work.
Good wiring Info here> http://www.madelectrical.com/electrical-tech.shtml and 1 & 3-wire Alt. Pics here> http://www.madelectrical.com/electri...hreewire.shtml
You may want to install Fuseable Links inline on wires from Solenoid to Interior/Ignition power wire & Alt to Solenoid etc.. for safety.
Fuseable Link Pics & Size Info:
http://www.madelectrical.com/electri...-gauges2.shtml bottom of page.
Old 06-15-2011, 06:20 PM
So what is the current generating system in the car. Is it wired for the original generator and electro/mechanical regulator? Or is there an interim modification of the GM 327 which could have a generator or an alternator the latter with an external regulator as with a generator or with an internally regulated alternator.
I have to express some surprise that the B+ wire is a 16 gauge, that's fairly small to hang everything but the starter from, I expect that to be at least 12 and would like to see a 10 gauge wire, especially if you're ever considering adding or have AC and a honking stereo in this project.
Bogie
Old 06-15-2011, 09:29 PM
Sweet-34's Avatar
Lost In The 50's
Bogie
Problem solved. I already had a one wire GM small alternator. I put on a 120 amp chrome alternator and run an 8 gauge wire from the back of the alternator to the battery post on the starter solenoid. I clipped the wire and ended it. The fuse panel is getting it's power from a good source. Thanks for all the information. Ron
GM 3-wire alternator wiring 350cruiser Electrical 3 12-29-2008 12:57 AM
Wiring a CS Alternator swap with only a 1 wire connector? Cousin_Joe Electrical 4 05-07-2008 03:05 PM
1 wire alternator wiring racinghick Electrical 6 04-08-2008 05:35 PM
Wiring a 1 wire alternator and starter 71novactb Electrical 7 02-09-2007 10:14 PM
Alternator Wiring 3-Wire Question leejoy Electrical 4 04-06-2006 09:26 AM
