wiring problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2011, 01:57 PM
wiring problem
I Bought A 72 Chevelle,was An Original Points Dist. Car.it Has Been Fitted With An Hei Dist. And The Harness Has Been Hacked A Bit.is There Someone Who Can Give Me A Diagram On How To Wire It Correctly Using The Original Harness?i Need To Know The Wires To Use And Ones To Ignore To Wire The Dist.,starter And Alt.my Alt Has Internal Regulator.also Should The Horn Relay On Firewall Have Power All The Time,even With Key Off? Thanks A Lot For Any Help.
Old 03-21-2011, 02:15 PM
kleen56's Avatar
Try this:
http://rmcavoy.freeshell.org/HEI.html
Old 03-21-2011, 11:16 PM
Here's a wiring diagram.
89 S10 wiring problem...... HELP!! Jeffs10 Electrical 1 08-02-2010 08:32 PM
72 ss wiring problem Zee Electrical 4 11-10-2009 07:37 PM
wiring problem vic molina Electrical 4 07-19-2007 07:05 AM
wiring problem new2chevy Electrical 7 12-06-2005 08:03 PM
wiring problem ltaylor Electrical 0 03-26-2003 06:36 AM
