Wiring Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2004, 12:48 PM
84camaro350's Avatar
Wiring Problems
I have a 1984 Camaro Sport Coupe That originally had the 2.8L V6 in it.
I am putting in a 350 SBC from a 1982 GMC Truck in it. The Truck has a non-ecc HEI distributor.
I am having trouble finding out what wires I need to use from the OEM wiring harness.
Harness has 2 plugs for the Distributor
1. 4 Wire Connector
2. 2 Wire Connector
HEI has:
1. 3 Wire Connector
2. Tach Spade
3. Batt Spade
Any help would be appreciated.
Old 03-22-2004, 02:05 PM
Ok, I found this in another thread.
Camaro Harness:
4 Wire Connector
Red: Ign - Hot in Run or Start
Black: Ground
Brown: Coil -
Yellow: Coil +
2 Wire Connector
Purple: Mag Pickup +
Orange: Mag Pickup -
Green: Tach
White: Trigger
Not sure exactly what the 4 wires into the 2 wire connector means. Unless the Green/Purple and Orange/White use the exact same signal for whatever they do....
But so far my best guess is that:
Green goes to Tach on HEI
Red goes to Batt on HEI
And If I remember Right the HEI has 3 wires in its plug.. White, Brown and Black...
Ground would be Black to Black?
I would then assume that Brown to Brown and Yellow to White for Coil?
If you guys have had the same issue come up when putting an older engine with HEI into the newer CC-Cars. Please offer some insight as to what wire goes where.
