wiring problems (SOMEONE HELP) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2006, 06:46 PM
I Am Ready To Smash My 64 Corvette. I Am Trying To Get The Fuel Gage To Work And Can Not . I Have Tryed Every Thing. Let Me Start By Telling You What I Have, I Have A New Fuel Send In The Tank, A Auto Meter Fuel Level Gage, And A Painless Wiring Harness. The Problem The Stock Sender Has 3 Terminals And I Can Not Figure Out How To Wire It. 1 Terminal Should Go The The Fuel Gage And Conect To The Sender Terminal, 1 Should Go To A Ground, And Where The Other Goes Is A Mystery. If Someone Has Any Idear Please Let Me Know I Am Going Carzy. By The Way I Can Get The Gage To Work Backwards . But I Would Like To Get This To Work Right. I Have Checked To Make Sure The Gage Reads From 0 To 90 And The Senser Came From Zips Corvettes So It Should Be Right And I Did Check It With A Meter.
Old 09-17-2006, 07:14 PM
NorthStar's Avatar
I DONT KNOW THE ANSWER TO YOUR QUESTION BUT MAN THATS HARD TO READ.
Here it is again.
I am ready to smash my 64 Corvette.
Trying to get the fuel gauge to work and can not figure it out. I have tried everything.
Let me start by telling you what I have.
I have a new fuel sender unit in the tank.
An Auto Meter fuel level gauge.
And Painless wiring harness.
The problem the stock sender has 3 terminals and I cant figure out how to wire it.
One wire terminal should go to fuel gauge and connect to sender terminal,
second should go to ground, and where other goes is a mystery.
If someone has any idea please let me know ASAP I am going crazy!
By the way I can get gauge to work backwards, but would like to get this to work correctly. I have checked to make sure gauge reads from 0 to 90 and sender unit came from Zips Corvettes so it should be right, and I did check it with a meter.
Old 09-17-2006, 07:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
From your description (and I believe I read and answered another post from you on this subject)..I think ... and I could be just wayyy wrong..but it almost sounds like you are confusing the gauge for the sender and visa versa..may just be my take on it though..
Try this:
Turn the key on..take the fuel gauge sender wire and ground it..It should peg in one direction or the other..THEN remove it from ground, It should peg in the other direction..
IF you have that..The gauge, and circuit is good from the tank to the gauge...
The gauge should have 3 wires on it S , G and I...the sender only two, unless the third is a HARD ground for the sender from the bladder to the frame.
Next, note which way the gauge went when you grounded the sender wire..E or F...If it pegged on F, and your sender is 90 to 0, It's working backward..showing an empty tank on full..and if it were empty, would show a full tank on empty..
The only way to be sure is pull the sender, hook the sender wire up and ground the sender body..move the float up and down and watch the gauge..If it moves backwards, get a 90 to 0, or whatever is the opposite of what you have now.
Doc
EDIT: Thanks Greg! That helped! (taking asprin now...)
Say the secret answer and the duck will fly down and give you $100:
Sender is Backward rated to the gauge...0 to 90 where a 90 to 0 should be..
Last edited by docvette; 09-17-2006 at 07:23 PM. Reason: I before E except after a 12 pack!
Old 09-19-2006, 09:12 AM
tanks
it worked i finaly got. now i can sleep at night. Thank you for your help. you havent hear the last from me on this project.
Old 09-19-2006, 04:33 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
OK, thanks for telling us..
Doc
POWER accesory wiring harness 91vette Electrical 13 04-11-2006 05:21 PM
Starter problems - unknown wiring professor-patrick Electrical 3 10-09-2005 05:16 PM
85' corvette wiring problems AARRRGGGHH!!! WakBordr7387 Electrical 9 08-14-2005 05:32 PM
wiring diagram for 87 chevy DDBrowneyesDD Electrical 3 07-18-2005 10:26 PM
1956 chevy belair Wiring Diagram NAK Electrical 1 05-12-2005 09:22 PM
